Subscription
laughingart74
How do I subscribe to the Black Friday deal. 29$/month. USA canada Mexico ?
7 REPLIES 7
AdilRoohi
I signed up today by downloading the Public Mobile app and transferring my lines from Fido.
Meow
@Handy1 wrote:
Thats not completely true it still possible to downgrade just not so freely and easily anymore
Well, that is a mixed bag; some customers Can and some CanNot downgrade.
That inconsistency is not really good as we all should be equal...
This one was a bit of a gift for existing customers.  Never say no the gift.
Meow
You can only get plans more expensive then what you currently have.
You will not be able to downgrade. Unless you open completely new account and close your current one.
hi @laughingart74
but eveyone sees the plan as PM is using targeted marketing now
But login My account and check Change Subscription page.  If it is there, then click Change on Renewal to schedule a change
@laughingart74  you can’t if your current plan cost more than $29 . Public mobile made it harder to downgrade plans . But you should see the $35-$45-$55 MEX plan available. If you don’t see the $35 one you can do immediate plan change to the $30 CAN/US plan then you should see the $35 MEX plan to change to using the change on next renewal option
adding but the $30  CAN/US plan only $1 more then $29 plan and gives you 20GB of data instead of 10GB
