Sim not working
tuoicu
So I activated my sim card and bought the 40$ plan. After trying everything possible (restarting, APN, network reset,…), my data is not working, it does not even appear LTE or 3G, and when i call, my phone is no user id, and i even went to the place that i bought the sim card, they did everything and stil didnt work. Please help me or refund my money because this is un acceptable.
JL9
Would need some more info, may be a stuck port or several other issues. Fill us in on some of the above questions if you get a chance.
@tuoicu  - what is your model of phone?
HI @tuoicu I don't think you need a refund.  I think it is just an activation issue.   You cannot even make calls?   PM CS agent can check the system and reprovision the account and sim.  Please open a ticket if you have not done so.  Not sure if you can login to your My Account, please open ticket by sending a message to PM CS Agent:
@tuoicu
Did you port your old number over PM or did you pick a new number?
There are extra steps if you are porting your old number.
Please let us know.
JK8
@tuoicu
 Contact our Customer Support Agents:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
