05-06-2022
05:54 PM
05-06-2022
11:32 PM
computergeek541
hi,
i've been trying to reactivate my phone number with your company and its telling me i do not have a number or number is invalid.
the number is xxxxxxxxxxxxx, email xxxxxxxxxxxxxxxxxxxxxxxxxx, cc email xxxxxxxxxxxxxxxxxxxxxx
05-06-2022 07:05 PM
Many times these type of situation is indeed an attempt at reactivating a plan that is over 90 days suspended unfortunately. So you will have to start fresh with the new rewards program etc.
05-06-2022 07:04 PM
May have been a typo, you are prob right in that it is 647
05-06-2022 06:36 PM - edited 05-06-2022 06:48 PM
Yeah 547-768-#### is not valid. 547 is not even a valid area code.
Adding: 647-768 on the other hand is in fact a Telus Mobility #.
What happens when you insert the sim in an unlocked compatible phone and dial 611? When was the last time you paid for this service? Are you able to login to the account?
05-06-2022 06:28 PM - edited 05-06-2022 06:32 PM
@AOEMService - that number you posted as is, is not transferable to Public Mobile (Telus owns Public and Koodo, so use this tool to check):
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
Is the number you posted correct? Please don't post it if it is different, just check in the above link to see if you can port it over.
edit, it doesn't sound like you are porting over...I know you said the word 'reactivate', but, now I am not sure...
Have you been a customer previously with Public Mobile, or are you trying to activate a new account/SIM card?
05-06-2022 06:04 PM
@AOEMService wrote:
the number is 547-xxx-xxxx,
HI @AOEMService
was it a typo? there is no 547 area code in Canada
05-06-2022 06:00 PM
HI @AOEMService How long you left PM? If over 90 days, then the account was permanently closed. You will need to get a new SIM card and activate as a new account
Take advantage of the weekend promotion, they have 2GB free for couple months for $35+
05-06-2022 05:59 PM - edited 05-06-2022 06:00 PM
Please edit out your personal info as this is a public forum. The little arrow on the right side of your post. Tap edit and you can delete the unnecessary personal info. Thx
Edit:
Oh dear it sounds like @HALIMACS is correct. When was your last payment?
To contact customer support :
Submit a support ticket via Simple--Simon the chat bot Click here
Or if you prefer or cannot submit a support ticket you may send a private message : Click here
To pre-verify add in your private messaging only your full name, address, email, phone # & 4 digit account pin #
05-06-2022 05:56 PM - edited 05-06-2022 05:57 PM
Two things, @AOEMService
This is a public forum with other customers, just like you, please edit your post by tapping the downward arrow upper right and edit this information out.
Re the inactive account, was the number inactive for more than 90 days, if so, it's permanently deactivated.
If it ISN'T, what happens when you dial *611 and what does your self-serve login say when you log in?
