01-02-2025
07:55 PM
01-03-2025
01:12 AM
computergeek541
01-10-2025 12:18 PM
I tried everything, APN settings, Tethered settings, including changing my telephone but it would not work.
I finally moved to a new service provider. Ten days without a proper connection was not acceptable.
01-02-2025 08:04 PM
@keithtel are you a new customer and haven't had data working before, or an existing customer that had data working in the past? Have you checked to make sure you have data available on your plan, you haven't used it all up and have you confirmed that you have cellular data turned on? If you are using an Android phone, have you checked that you do not have any data limits set? More info from your side would be helpful to let us know what you have tried so far or confirmed.
01-02-2025 07:58 PM
Hi
Can you provide more information, can you receive/make calls ?
Can you get/send messages ?
Did you try to reboot the phone ?
Did you try to change Network Mode or Change configurations under Mobile Networks ?
Thanks.
01-02-2025 07:58 PM - edited 01-02-2025 07:59 PM
hi @keithtel
what phone do you have?
no data is usually a problem with the APN settings
start with Reset Network Settings and see if it helps
if not, you might need to manually update APN
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
