01-03-2025 12:52 AM
I was setting up my new account/sim. I got my old number ported over but my new esim won't work and never got qr cide email. when I try to login to my account I get a forbidden A1 message on my phone and PC
01-03-2025 05:03 AM
Check the spam folder for the QR code for you to scan to complete the porting process.
Also, the email may take a little longer so wait for the email from PM.
If it haven’t arrived then contact a CS_Agent to check on the porting.
01-03-2025 12:59 AM
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
