07-26-2022 11:33 AM
I am loving my Public Mobile service. I have been on the $40 5GB plan at 3G speed for approx. 3 years
Has anyone recently switched to the 4G? I understand it should be up to 30 times faster.
What kind of difference are you noticing?
Is it just as reliable or better?
Will it make a difference when I travel occasionally to the US and add a US plan?
Would there be any disadvantage?
I'd like some feedback to help me decide if I should make the switch...
Thanks in advance everyone! 😁
07-26-2022 12:47 PM - edited 07-26-2022 12:48 PM
@DDM69 wrote:I thought I heard that the US will no longer be supporting 3G. So I would like to make sure I still have data when travelling south.
@DDM69 don't get mix up with the 3G network shutdown and our 4G or 3G plans they are offering
3G or 4G plan is just a difference between the speed, not really about the access to 3G or 4G network.
BOTH 3G and 4G plans have access to 3G or 4G network
So, in short, you can still buy and use US roaming addon with your 3G plan.
When you are in US , when you using your roaming, you will be accessing the 4G network there for data and possibly the 2G network on T-Mobile for voice
07-26-2022 12:44 PM
07-26-2022 12:29 PM - edited 07-26-2022 12:33 PM
It is more speed than reliability. If you are a mobile gamer, the speed could be significant
If you are noticing slowness now, then the speed upgrade could help
If you do not download a lot, do not download and watch 4K movies, then the speed likely won't be very useful to you
For US, I do not think the speed is capped when you are in US roaming anyway
Any disadvantage? your pocket $$
If you are happy with the speed you have now, I think there is no need to make the change
07-26-2022 12:23 PM
I doubt you will ever see any speed difference unless you do speed check.
Difference is not like dial-up vs. high speed.
There will be no difference for US travels. 4G affects data only. Voice still uses 3G.
07-26-2022 11:50 AM
@DDM69 hi it won't make a diference when you go to the states,if youlike what you have now, why change?
