Service suddenly not working after ~2 years
Rekehart
As in the title, I've been with public for more than 2 years now with the same phone(Huawei P20) . A few days ago I lost network service, even though my payment was successful and my account status is still active. My phone still works.
I saw on the website that the distributor has changed, but the page to check if your phone is compatible is no longer available either.(just asks you to buy a sim card)
Restarting the phone/ airplane mode etc has not solved the issue.
9 REPLIES 9
hycm53
According this website information that if your phone was made for globe then has 2 frequency bands for 3G, but if it made for China then it has only one frequency band for 3G. This information doesn't mean your phone won't make a call or receive a call, but may has a problem for receiving signal.
https://www.kimovil.com/en/frequency-checker/CA/huawei-p20-lite
thefonz22
I turned wifi off and still can't make calls. But can receive calls sometimes.Strange
Hi @thefonz22 can you make calls away from where you are now? could be network issue there or could be because of VoLTE.
since you opened ticket , wait for agent to reset the account for you first
thefonz22
Pixel 6 user here. Suddenly unable to make or receive calls today. Mobile internet and texting works though. I have a support ticket going at the moment.
kletap
I'm having the exact same issue. What has been going on with public mobile these days?
The method of SIM card distribution is unrelated to your service. Public Mobile is owned by the same company as when you stared your service here.  A phone that was compatible 2 years ago is still compatible today.  I would suggest check the status of  your IMEI at devicecheck.ca.
hi @Rekehart
no operator change.  but maybe due to VoLTE opent ticket for help
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@Rekehart
Check to see if there is an outage in your area. Check outage map:
https://istheservicedowncanada.com/status/telus/map
If there are no outage, you need to contact a CS_Agent (Moderator) to look into the issue for you. It could be a problem o their end.
dabr
@Rekehart    You said the phone works (calls/texts/data)?  Or not?
The phone compatibility checker has never had a complete list of compatible devices, so you may not be able to glean much info from it anyhow.   As to the distributor, I believe that only refers to where PM SIM cards are being sold as the number of vendors have been reduced.
