Just started with Public Mobil, paid, activated the card but it’s not working.
HeidiMK
Why is my phone not working?  Just activated the card.
hairbag1
@HeidiMK
did you just recently port your number to Public Mobile from your old network ?
I'll pm you the phone number to call for assistance porting. Check the little mailbox icon on top right side of page.
hycm53
Try turn off the phone, remove sim card , wait a couple minutes then put the sim card in and reboot the phone.
Hi @HeidiMK did you request porting I'm number?  outbound calls work?
if both outbound and inbound calls do not work, just open ticket with PM agent for them to setup the sim on the system again
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
