2 hours ago
I purchased 15 days of mobile service with Public Mobile for the USA on September 8th. I entered the USA on September 9th but cannot use my phone while here. It has worked for me before. I need to be able to use my phone while here. Help!
2 hours ago
@Sparkles51 Roaming must be toggled on if you haven’t done so yet.
2 hours ago
Critical part to US roaming depends on T-Mobile/AT&T/Verizon coverage and whether you can connect successfully onto either network.
With your voice issue , make sure VoLTE is enabled on the device setting. And if it does not work, try to change the Network to T-Mobile ONLY, and change Preferred Network Type or Network Mode to 2G and see if the calls go through.
Also, you can download VoIP app TextNow as a workaround to make calls and text if you have Wifi or if your roaming has data component and data is working
2 hours ago
HI @Sparkles51
your plan has data and data works?
what phone do you have? try connect to T-Mobile and test
