06-03-2023 03:02 PM
Used up all my data, and have a week left before renewal date. I remember I was able to renew my plan early, but cannot seem to find that option now. Is there a way around this? My renewal plan is the $39 special, which isnt offered anymore so I can't go through the new subscription way without losing my existing plan.
06-30-2025 05:03 PM
hi @Moon3
no change to the rule about early renewal
you don't renewal the plan early yourself, but you need to ask PM support agent and they will renew it early for you
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
06-30-2025 05:01 PM
I guess the rules have changed? I am unable to renew my daughter's plan early (plan is no longer offered)
06-04-2023 01:06 AM
@hairbag1 wrote:I just tested to see if I could renew current plan right away and...whadya' know...it is selectable !
Things change around here from one day to the next. Used to be a CSA was req'd to renew current plan immediately. 😬
I'm not so sure if that actually changed or if that members didn't know about this previously. I noiticed this Self Serve account behavior quite a while a ago and reported this to the Community, but I wasn't going to actually go through with a plan change that I wish to proceed with.
06-03-2023 10:16 PM
@dabr Good to know , thank you for sharing.
06-03-2023 10:14 PM
@Handy1 Just as an FYI for everyone regarding being able to change to the same plan early, it seems we don't even need to select Change Plan (Subscription) after selecting Subscriptions/Add-ons any longer, instead can click the Change Subscription link top right of the overview page and all the plan offerings become available. So one less step from selecting Subscriptions/Add-ons tab. Not a big deal but thought it was interesting..
06-03-2023 04:31 PM
@dabr Yes it would be archived somewhere , you asked me to up date if it worked , and I forgot to do that… but yea it works so this is my feedback LOL
06-03-2023 04:29 PM
@Handy1 Ohh, yes, of course, now I remember there was a discussion about this in an old thread..
06-03-2023 04:26 PM
@dabr It has you and I discussed this not long after I joined community
06-03-2023 04:24 PM
I believe this workaround (temporarily select Change at Renewal) has been available for several months now, or since the update to the account last summer.
06-03-2023 04:07 PM
The $39 20GB plan is still available. It just doesn't show up for you because it's selected for your scheduled plan change.
06-03-2023 03:37 PM
@hairbag1 you forgot one important step.. CLICK on it ,,🤣
06-03-2023 03:35 PM
@hairbag1 - ooooh 🙂
Did you go so far as to hit the "Change Now"? I am afraid to. LOL
06-03-2023 03:19 PM
06-03-2023 03:06 PM
@TopherC unless something changed that I am not aware of, I don't believe you can renew the same plan early, so either purchase a data addon or contact CSA to get the plan renewed early for you.
Note, that you do not get any funds already paid in this cycle, no prorating. Nor, do you get your rewards applied on a plan that is renewed before your regular scheduled renewal date.
Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
06-03-2023 03:04 PM - edited 06-03-2023 03:04 PM
Early renewal
assuming at least that your current plan is still one that is offered . If you go into your Self Serve account and schedule a plan change to a different plan, the Self Serve page will then alllow you to select your current plan as an immediate plan change if you go back to change your plan again…otherwise if your existing plan is not there you will need supports help with this
