Recipients cannot hear me
Pat123451
Hi. I’m having issues where the person I’m calling says I’m breaking up/they can’t hear me but I hear them fine. I’m using an iPhone on Public Mobile. Issue is happening whether I’m calling a land line or other carrier or another Public Mobile phone. I’ve also tried calling people on my husband’s Android Public Mobile phone and got the same issue. This is getting annoying and thought I’d check here for help. Maybe it’s time to change carrier? Hope not. Thank you.
@Chalupa_Batman wrote:
Hello @Pat123451
Go into your network settings and reset your network and then reboot. This should clear it up.
Dumb question, how does this address the problem?  This is not a network connection related problem.  Network resets will remove past saved network settings like WiFi passwords.  Very annoying to restore.
AK32
How is the service in your area? do you normally have full bars?
If you're experiencing the same issue with both phones, i would try to see if its happening in another location maybe closer to the towers/in the city. Or if you have any family members/friends who can test another phone on a different carrier in your area to see if its a Telus/PM issue or a location issue.
Im assuming you've already tried the routine troubleshooting methods, but if not, try restarting your phone, going into settings and resetting Network settings (this will remove all wifi passwords just so youre aware).
hi @Pat123451
you can start with clicking Reset Network Settings on your phone and see if it help
And of course, make sure your iOS is updated and also update the Carrier Profile
if possible, test the sim card on another phone and that can tell if it is a device problem or network
hairbag1
@Pat123451
if it happens with both phones from same location...sounds like a location issue. Try making a few calls from a different area. Has it worked properly in same location, in the past ?
@Pat123451  Try the different network mode 3G 4G/LTE or 5G see if that helps any . Also can try rebooting the phone or reset network settings and see if the at makes a difference . Seems strange you both having same issue thou . Maybe there’s a outage in your area
Chalupa_Batman
Hello @Pat123451
