05-17-2022 04:52 PM - last edited on 05-17-2022 05:09 PM by computergeek541
Does anyone know how can I receive calls when I'm out of the country? What add-on should I purchase?
Thanks in advance
05-17-2022 06:45 PM
05-17-2022 06:35 PM
Hi @DDM69, US Caribbean Islands? which one?
05-17-2022 06:20 PM
The US roaming package will also cover a couple US caribbean islands.
05-17-2022 06:16 PM
05-17-2022 05:13 PM
Depending on where you are going and for how long you can either get a prepaid local option and bring your phone with you and put that sim in, or you can get various free voip apps (although free versions usually won't work for 2FA)
05-17-2022 04:58 PM
05-17-2022 04:55 PM - edited 05-17-2022 04:55 PM
Does that mean if I travel outside North America to a different country anywhere else there is no way for me to get service? Not even receive texts and calls?
05-17-2022 04:53 PM
