a month ago
Hey everyone,
I am at a dead end trying to get Public Mobile MMS working on my new TCL Flip (4058E) and am hoping someone here has a fix. Ultimately, I just want a phone that can only receive calls and texts/images, but it needs to be able to receive images and group messages because, well, that's not really negotiable unless I want to explain to everyone that sends an mms message that I can't get them.
I specifically bought the 4058E because I verified it was on the Public Mobile compatibility whitelist, and it was suggested in the previous thread I created, as well as other threads (like HERE). I wanted to make sure I had an up-to-date Canadian version of the hardware instead of the older US Cellular model (4058L) which gave me the exact same MMS issues. For context, my Moto G Stylus 2023 works on PM with the exact same SIM.
Here is everything I have already tried:
The Result: Standard SMS texts and calls work completely fine, but MMS message (images and group texts) refuse to send or receive.
Given that I have ADB access to this device, is there anything else I can try? Or is this phone officially a dead end for PM MMSs?
Other info:
ro.product.model: 4058E
ro.product.name: 4058E
ro.product.device: Gflip6_CAN
ro.tct.curef: 4058E-2AB6CA1
ro.board.platform: mt6739
ro.build.version.release: 11
ro.build.version.sdk: 30
ro.build.fingerprint: TCL/4058E/Gflip6_CAN:11/RP1A.200720.011/QK6G:user/release-keys
gsm.version.baseband: MOLY.LR12A.R3.MP.V179.5.P56
vendor.gsm.project.baseband: TK_MD_L4(LWCTG_R3_6739)
ro.vendor.md_apps.load_date: 2024/05/28 10:57:18 GMT +08:00
ro.telephony.default_network: 9,9,9,9
a month ago
Hello! I honestly tried a bunch of different ones. The text address and numerical, as well as the two different ports (80 and 8799?). I tried splitting the APN into data and MMS as well.
However, since posting this, I may have made a discovery but I'm not certain if it's true. It seems that Public processes MMS messages a bit differently than other carriers and when I modified the phone to enable ADB, I may have inadvertently removed part of the system that would have properly routed the MMS.
I've pasted a description below that may not be accurate, but it does look like there's a difference in the way that PM handles MMS.
"On premium smartphones like your Moto G Stylus, the operating system's built-in carrier data table acts as a translator, seamlessly routing the MMS image packets through that specific gateway. Because your TCL Flip lacks that translation code entirely, it flatly drops the proxy data handshake.
Other providers do not require complex, nested MVNO translation proxy routing rules to send a picture message. They use straightforward, standard APN multimedia server endpoints that are already baked into the baseline MediaTek Android network stack."
a month ago
hi @Billybobh
Telus (PM) has retired some legacy servers and old phones from 2017 before will be affected
and check if you have any of these APN settings and update it accordingly
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
a month ago - last edited a month ago
I have used this phone myself. Now, I may make comments that sound stupid up front, however, I am just spit balling and seeing what sticks to the wall. 🙂
Make sure data is turned on. Go to Settings, Wireless and Networks, Mobile Network. Make sure Cellular Data is turned on.
Clearing the message app cache is an option. Settings, Apps, messages. Select storage and clear cache. Then reboot.
What APN settings did you use?
https://www.publicmobile.ca/en/get-help/articles/set-up-data-on-an-android-phone
Ill keep this window open to help as best as I can.
