10-05-2021 05:31 PM - edited 01-06-2022 03:29 AM
I have returned my new cell phone and need to cancel the Public Mobile monthly charges,
10-05-2021 10:37 PM
@cynstar you can also use *611 to cancel Autopay
click 5 for Autopay and 2 to disable.
But, make sure you are not planning to port your number to another provider.. If you are porting number out , you must have an active account.
10-05-2021 10:30 PM
@cynstar wrote:How do I cancel a monthly charge?
Were you able to remove your Autopay, or credit card through your Self Serve account?
If you are still having issues doing this after suggestions given, then contact Customer Support Agents by submitting a ticket.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 - Faster - Click the bubble comment circle on the bottom right-hand side of your screen,
or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Private Message to Public Mobile Customer Support Agents (CSA)
10-05-2021 06:41 PM - edited 10-05-2021 06:42 PM
An upcoming renewal? Remove autopay or suspend service via lost/stolen. I prefer the latter. If you suspend before midnight eastern on the night of renewal your voicemail will remain active but after reactivating you will have to contact customer support to have your rewards applied manually. Pay and reactivate your plan by day 89 to keep your account and phone number from being cancelled and deactivated.
10-05-2021 06:05 PM
10-05-2021 05:56 PM - edited 10-05-2021 05:57 PM
- Quick and keep your phone number.
Disable autopay and remove autopay credit card info to stop autopay and port your number to another provider. Your account will be cancelled right away.
- Slow and do not keep your phone number.
Remove autopay credit card info to stop autopay. Your account will be suspended without payment at your next renewal date. 90 days after suspension, your account will be canceled. You have 90 days to change your mind by paying and reactivate your account.
- ‘Sell’ your plan and do not keep your phone number
If you have a plan with high demand, you can let someone to take over your plan. Your phone number will go with the plan to the new owner.
10-05-2021 05:51 PM - edited 10-05-2021 05:53 PM
If you have autopay setup then remove your credit card.
Sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘Register for AutoPay’. From here, you can sign up for AutoPay or remove the feature, if you no longer want payments to automatically occur. If you would like to change the card that is automatically charged, scroll to the bottom of the ‘Payment’ tab, then select ‘Manage my card’. This will allow you to update or remove your credit or Visa Debit card.
10-05-2021 05:42 PM - edited 10-05-2021 05:42 PM
10-05-2021 05:42 PM - edited 10-05-2021 05:43 PM
by *611
or sign in to Self-Serve, to review your account,
How To Update or Remove Your Payment Card
To update or remove your credit or Visa debit card details,
1. sign in to Self-Serve. Once signed in,
2. click on the ‘Payment’ tab,
then scroll to the bottom of the page and select ‘Manage my card’.
you will have the option to either select ‘Replace this card’, or ‘Remove this card’.
You will need to review and confirm this change to your account,
10-05-2021 05:40 PM
How do I cancel monthly payment since I no longer have cell phone
10-05-2021 05:34 PM - edited 10-05-2021 05:34 PM
@cynstar : If you can log in to your account, just remove the payment card and the account will suspend. Then after 90 days it will deactivate.
Or if you know your 4 digit PIN, you can dial 18554public and toggle off autopay and the same should happen.
Edit: speedy again 🙂
10-05-2021 05:33 PM
@cynstar wrote:I have returned my new cell phone and need to cancel the Public Mobile monthly charges,
If you are on autopay with PM call 18554PUBLIC and cancel autopay.
