incoming calls
09-12-2021 12:26 AM - edited 01-06-2022 03:29 AM
09-12-2021 01:06 AM
@tin-vu1952 incoming calls as subject and blank on the body.. i guess you have no incoming calls?? 🙂
Threre has been some issue with PM for incoming calls last couple days. Give us the details and maybe we can assist.
09-12-2021 12:38 AM
@tin-vu1952 what plan are you on? There are a couple grandfathered plans that have limited incoming call minutes.
Or if you are a new subscriber then probably an incomplete port (assuming outgoing calls work)
09-12-2021 12:37 AM
@Anonymous wrote:@cavemantoronto : Do you have tags on? OP wrote in the tags box. Not much more there 🙂
i see the post now. Tags were off. There's nothing much but saying they can't get calls.
09-12-2021 12:32 AM
Are you having issues with incoming calls and text? There have been issues lately.
Can you try:
1. Reset the network settings and reboot.
2. Set your preferred network to 3G and reboot.
3. Put your sim in another phone and then back again.
09-12-2021 12:32 AM
09-12-2021 12:30 AM
Your post is blank. Do you have questions? I guess that you can't receive calls. Did you ask for a number to be ported in?
