Proof of purchase
Sakara
@Sakara
Anyone can view your post on this forum and use your vouchers.
Edit by popping to remove 2 photo of voucher.
12 REPLIES 12
darlicious
@popping
Thx to you too.....where did you pop up from?
darlicious
@Sakara
Call 611 from your phone. Press (1) and (1) again. Enter the 12 digit PIN # from your voucher. If you added it successfully it will be confirmed by 611 and you will also get a confirmation text. Then add the second vouchers 12 digit PIN #.  Log out and reboot your phone. Your plan will automatically reactivate.
Meow
@Sakara wrote:
The minutes are on my phone but plan never activated
Do you have active service with PM?
So you are saying you were able to add those vouchers to you account?
What exactly do you try to accomplish? To reactivate suspended account?
Pictures are gone! Good!
darlicious
@Dunkman
#SLAMDUNKMAN!!
@Sakara
Please remove the details of the image. This is a public Community forum…no wonder you have any money in your account because people can skim it.
darlicious
@Dunkman
Please edit the OP's post. Mucho rapido. Gracias.
@Sakara   delete from the image library and the images on the post will be gone:
https://productioncommunity.publicmobile.ca/t5/media/gallerypage/user-id/232080/tab/all
put your mouse on top of the image, click on the X and it will delete it
darlicious
@Sakara
Oh dear...please go to the arrow at the right of your post and edit out your photos. And then delete them from your image library in your profile.
dust2dust
Where did you get the vouchers from? Have you used vouchers from there before?
You're showing anonymous money. Remove those images.
JL9
What steps did you go through to activate?
@Sakara   What exactly are you trying to do ?  Activate new plan?
or top up and reactivate existing plan?
If you try to top up, did you top up via *611 or My Account?  If you login to My Account, do you see Available Fund = the amount you topped up there?  And the Account status still showing suspended?  Give us more info
Sakara
