No data
Kgreen
  • I have not had data for over a week.
@Kgreen   Give it another try
If you have another phone around, put your PM SIM there and try it on the other phone. This could re-provision your SIM/Account.  There were couple users with that problem around 2 weeks ago and that fixed it
if it still not working, may I know what brand/model of your phone?  If it is an iPhone, make sure you update your iOS to the latest stable version (non beta)
And , open a ticket with PM Support:
1. If you have access to Self-Serve My account: For faster response (2-48 hours) , Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. If you don't have access to My Account or have trouble with above method: you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened.  CS Agent will reply and work with you  via messaging there
Kgreen
No. I have used no data this month and still can’t. It’s ok. I’m going to another carrier next month. Done with Public!
@Kgreen voice calls ok?  did you login to My Account and do you see a line about data in the My Data & addons section?
dust2dust
Did you have data with your Public account before that? Have you checked for data on your account? Maybe you've used it all.
