Activation, cancelling plan before activation
jolka
I just purchased a plan and ordered sim card.  My card was charged for a month already.  I did not realize PM does not have roaming plans to Europe and Thailand and  I am just going there next month.  Two questions:
1. Can  I cancel the purchase  ( I just ordered the card today)
2. How long do I  have to activate the plan  -  for example can I activate it March and will my card be charged between now and activation ?
jolka
Unfortunately, my card was charged right the way and  already processed. Trying to resolve the issue with an agent.  Thank you for your advice.
jolka
thank you for your quick response. I sent a message to a support agent
eddieO
@jolka you have 30 days to activate your plan so March would be too far out. If you are thinking about cancelling you will need to reach out to a support agent:
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
hairbag1
@jolka
your card won't continue to be charged until you activate a new Public Mobile account.  If you wish to cancel, use this link to message Customer Support...
