03-04-2024 10:38 AM
I just switched from fido to public. My iPhone have network signal and can make calls and receive messages, but I cannot receive messages or receive calls. eSIM card. How to fix it? Thanks.
03-04-2024 01:35 PM
Sounds like your port is incomplete. Did you answer “YES” to text message from Fido to authorize port? If you did, then it can take 2 hours or more to fully port your number.
03-04-2024 10:47 AM
if you cannot make outbound calls and no network signal, it is a sim care setup problem. You will need to open ticket with PM support agent. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-04-2024 10:45 AM
watch the little envelop icon on top right side of the page. I just sent you a number to call for help with your porting problem. Welcome to PM.
