porting number
Slowgold99
I'm moving to ontario but can I keep my quebec number when porting to public mobile?
@Slowgold99   Yes you can move from Koodo to Public Mobile.  The only difference is that if your Koodo plan is prepaid you will need customer service to do the number transfer.  For Koodo postpaid you can do it yourself during or after activation.
Yes it is, as long as your number is eligible.
Slowgold99
so moving from Koodo to PM is not allowed?
Sansan
Yes you can transfer your number from one province to another.
Here are some important things to know regarding porting.
https://www.publicmobile.ca/en/on/get-help/articles/transfer-your-number#:~:text=If%20you%20are%20ne....
Meow
You can port any number to PM. The only thing you cannot do is transfer PM number to new PM account.
Confirm first if your number is eligible to port to PM
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
