12-13-2024 01:08 PM - last edited on 12-13-2024 02:43 PM by computergeek541
Text and data was fine. The issue started on Wednesday.
The phone can be worked with other carrier and another Public mobile SIM card . This SIM card can also works fine with other phones.
tried enable VolET etc and can not change to prefer 3G as looks recently Public mobile disable 3G network?
a month ago
Last update: I contact agent,They did reset the network on their side.then reboot and test not working , so I gave up and went to sleep . Next morning , everything working fine .
12-13-2024 02:10 PM
Thank you . I did raise a case with cs_agent . Will update you if it gets resolved.
12-13-2024 01:27 PM
@Chouchou2008 That’s a strange one for sure , if it was the SIM card then it shouldn’t work in another phone . But you’re saying it does . And it’s not the phone because another public SIM card work in it . So this is a true mystery I’m not sure what else to try then . I’m stumped 🤔
12-13-2024 01:22 PM
It is xiaomi. But my another public SIM card can work in this phone. And this SIM card can work fine on my iPhone . Only issue is when the SIM card with the cell phone together. Maybe the SIM card is too old to with the cell phone.
12-13-2024 01:15 PM
@Chouchou2008 What phone you have ? You mentioned voLTE here’s Pm voLTE whitelist
VoLTE white list
12-13-2024 01:13 PM
I did everything I can , spent whole night last night. I even switch SIM cards and phone to trouble shooting
12-13-2024 01:09 PM
@Chouchou2008 And you tried rebooting the phone or reset network settings ? See if that helps if you haven’t already if same as support to refresh your account
