Number transfer issue
GlennP
I am trying to transfer a teksavvy coop landline to new public mobile account.  I was told by teksavvy that they are incorrectly identified as a re-seller on the transfer form so it is getting rejected. No one appears to be able to help.
@Handy1 wrote:
@GlennP
Check to see if # can be ported
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
Teksavvy is based out of Southwestern Ontario, so it's unlikely (but not impossible) that the number isn't portable to Public Mobile.
@GlennP
it a check on Koodo site cit PM and Koodo both owned by Telus so you can use that check to see if the number can be ported into PM
and open ticket with support to see what provider to pick from the list to port
GlennP
Not a Koodo #
