01-30-2025 07:51 PM
Hi, ever since I switched to PM I can't send a pic by text message, I can receive them with no problem. I have mobile data on, all the apn settings match what I have found on the forum. I have restarted the phone.....
Any ideas,? Please and thank you
02-02-2025 09:31 AM
Ok so the first field APN sp.mb.com
Only works on my phone if it is all capital letters
Which is good to know for people who are still having this issue!
02-02-2025 08:09 AM
Why does this work for them but not for me? I use an Andriod
Everytime there is an update my picture messaging craps out and I can no longer send pics so I try this over and over again only got it to work once in the past. It's the most annoying thing ever I need picture messaging for my work.
Is there an uppercase sensitive issue in the input? Am I missing a capital letter or something silly?
I am tired of this issue
01-30-2025 11:10 PM
Self solution removed, solution reassigned
01-30-2025 10:56 PM
That fixed it, thank you so very much for your input
01-30-2025 10:45 PM
Hi, it is a samsung s7. Those are definitely different apn settings then Iv'e seen before, I will try them
01-30-2025 10:40 PM
hi @rat772
what phone do you have?
check if you have these APN settings
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APN Type: default,supl,mms
01-30-2025 10:37 PM
I tried that with no luck..
01-30-2025 10:36 PM
I use the original texting app. Internet and calls, regular texting and everything works, I can even send pics in messenger
01-30-2025 07:57 PM
@rat772 wrote:Hi, ever since I switched to PM I can't send a pic by text message, I can receive them with no problem. I have mobile data on, all the apn settings match what I have found on the forum. I have restarted the phone.....
Hey @rat772
Something that worked for a buddy of mine was to go into his network settings, turn off automatic and pick Public Mobile and then rebooted. Not sure why but it worked.
01-30-2025 07:54 PM
Do you use Native texting app or 3rd party app? How about other services? Calls, Internet?
Correct, you have to have Data on in order for MMS to go in/out.
