Transfer esim to new phone
tomasd
I recently signed up for public mobile and then a week later I got a new phone. How do I transfer the esim to the new device?
21 REPLIES 21
Ck_PM
Public Mobile
Public Mobile
Hi all, just wanted to clear up some confusion. If you're already with Public Mobile and are looking to transfer your Public Mobile eSIM to a new device you've purchased, it will not cost you anything. You only pay the eSIM fee if it's your first time purchasing an eSIM with Public Mobile!
CFurga
Worked fine for me, maybe this was added later. I didn't touch any thing with the old phone, just purchased a 2nd e-sim on the new phone, installed it, and the old phone disconnected from the network automatically.
@v2k604
To rebuy new eSIM, First, download the app on your new phone, click   or    at the bottom left to bring up the menu and go to Subscription & Add-on page, scroll down to the bottom and click Shop SIM Card Now.  You can buy and install eSIM from there
HI @v2k604
download the app on your phone, go to Subscription & Addon and then Shop sim card, pick eSIM
but if your phone still accept physical sim, i suggest you to go back physical sim.  It is easier and free to change phone with physical sim
v2k604
I'm stuck on this now, all the support says you need to buy another eSIM on the app, but it's nowhere to be found.  How do I get a SIM/eSIM?
@tomasd   No, no luck.  I message support and confirmed that at the moment, the system limitation still there, ie, you have to go back to physical sim  😞
tomasd
Thank you. I wrote support earlier and they didn't mention that option, in fact they specifically said it wasn't possible.  Where did you hear about this? Would you be able to share a link that I could provide to support when I contact them?
@tomasd  you might be lucky!!!
look like new development as of today.  I see people posted saying support able to sell a new eSIM for $5 for used on new phone
So, please message support to confirm.  And if that is now doable, please reply here and let us know, and share the steps to do so.  Thanks
To message support:
HI @tomasd
get the sim card from Telus or Koodo store or Amazon
Then go to My Account, Profile page, there is a sim card number there, click on it and you can update to the new sim card number.  Use a computer to go through that, someone reported issues using a phone.
tomasd
And how would I do that?
tomasd
Thanks, so how do I switch to a physical sim card?
HI @tomasd   yes, there is no porting within same provider.  PM no longer swap numbers between 2 accounts now
So, in your case, there is really nothing you can do other than getting a physical sim
tomasd
But how would that work? Could I "port" my number from the current e-sim to the new e-sim? I've never heard of porting within the same carrier.
CS_Agent
Customer Support Agent
Hi there.
And thanks for sharing your concern with our community, they are the best.
In case you still need more information, we kindly advise for you to double-check your inbox, on your community account, in case one of our customer services representatives has already replied to your private message.
Have a great rest of your day 😄
Public Mobile Team.
pmbc
@tomasd wrote:
lol
Good thing PM is prepaid! 😄
tomasd
lol
@tomasd  I believe they will have the feature soon
how about carrying two phones in the mean time?
tomasd
Thanks, I guess my time with Public Mobile is going to be very short. I'll be porting away now.
@tomasd   sorry, it has been confirmed that no esim transfer to another phone , or even if the esim profile was deleted.  These functions will be available later, but not at the moment 😞
you can message support again to confirm , you can message them here:
tomasd
I can't do that, I have a different sim card in the physical slot.
@tomasd   sorry, at this momentn, eSIM cannot be transferred.
If you are going with your new phone, you will need to change it back to Physical sim
