09-07-2021 09:05 AM - edited 01-06-2022 03:25 AM
09-07-2021 08:31 PM
Lol.....next time!
09-07-2021 08:27 PM
@Niinnjjaa wrote:Hi,
My account seems to have been suspended - I can't make a payment or top up anything - can someone please help?
IF you still have services, this could be your account going through the normal renewal process. The SELF SERVE account can say "expired" or "suspended" on the day of or before your plan is due to renew.
So if this is the case, ignore these messages on your SELF SERVE account.
09-07-2021 10:10 AM
You can purchase a voucher and top up thru 611. Once connected press (1) then (1) again and enter the 12 digit pin #. Once successfully added hang up and reboot if necessary. If you added enough funds you will automatically reactivate your plan. Otherwise.....
I just click on one time payment and in the middle of the page you can click on manage my card. Then I follow this procedure....
Follow this method when making a manual payment/adding a card to the account....only use the emboldened portion of the instructions if the payment card is already on file.
Once you successfully update your card do not attempt your payment immediately. Log out/in then go to make a payment to pay for your renewal. Otherwise if you were not suspended I would recommend a $1 test payment. Follow my further instructions for a successful payment to unsuspend your account.
Do not try more than two attempts at adding a card or payments ( successful or not) or you will continue to get this message. Wait at least 1 hour to try a third time another hour for your 5th try....and so on....and do not make more than 4 unsuccessful tries with the same card in a 24 hour period or you will trigger a fraud alert lock out requiring assistance from customer support.
Go to make a payment. Choose the "other amount" option and add $1 more than the amount owing and submit the payment. If that is successful go back to your overview page and if it does not say active click on the reactivate button. If that works log out and reboot. If that does not work and your payment is in your balance rather than showing $1 then go to the usage or plans page. Click on lost/stolen and suspend your service. Log out/in. Resume your service. Your balance should now be $1. Log out and reboot.
09-07-2021 09:11 AM
Is your phone working now? Did autopay fail?
You might want to manually load up funds equivalent to your plans fee. Once the funds load, your account should reactivate.
The website can be finicky at times also. Trying a different web browser, clearing cache or incognito mode. Also sometimes if you try payment several times, the payment system locks out and you can try again in one hour.
You can also manually load fund by dialing 611.
https://productioncommunity.publicmobile.ca/t5/Self-Serve/611-IVR-Menu-System/m-p/289352
