03-19-2025
11:13 AM
- last edited
4 weeks ago
Dunkman
Question for the community: anyone experiencing not hearing an outgoing ring tone (outgoing calls) when making calls? It says silent until, all of sudden, someone on the other end picks up. Happen randomly and indiscriminately. Hoping someone else has run into this same problem and has a solution.
2 weeks ago
Doesn't work for me either.
3 weeks ago
Is your plan with Telus or Public Mobile (PM). If PM, how did you get them to phone you?
3 weeks ago
Gurus at Telus called early this morning to test my phone. Ring back tone is now working for me. Apparently the solution is individual -- not broad network. Thanks to all that worked on this. Everyone learned something.
03-21-2025 05:30 AM
No. Network gurus are supposed to be on it.
03-20-2025 09:32 PM
I am having the same concern. Were you ever able to resolve the issue? If yes, what was the resolution?
03-20-2025 01:37 PM
I do not get ring back when I dial mobile lines. I do however get ring back when calling land lines. My issue has been raised to the network gurus. Apparently this has happened to a number of customers using various phones and different networks. This is what I got when I used AI to help with this:
03-19-2025 02:13 PM
Do you have an iPhone? Search show s lots of similar complaints in Reddit. One possible resolution is just to restart your phone.
I have an Android, Pixel. I have occasionally experienced this but not enough to be bothered by it. Good luck.
03-19-2025 11:41 AM - edited 03-19-2025 11:42 AM
@Mastert74 I don't know how cell phones work in that regard but my understanding was with landlines that it is the exchange that sends the ringing signal back to the caller. With cell phones I'm assuming sometimes there's a glitch that causes the signal not to be sent, or perhaps the connection is too quick as with a VoLTE call vs non-VoLTE. But any more than this speculation is over my head lol!
03-19-2025 11:29 AM
@Phil_Adelphus ya...seems to be a PM to PM issue. Also happens from PM to Bell (i know they use the same network though Bell/Telus). If it is a routing issue, not sure PM can do anything about it?
03-19-2025 11:24 AM
@Mastert74 I've noticed it occasionally, not just with PM. Since the calls worked I didn't look for a solution. I suspect it is more an issue with the routing connection/s.
