03-21-2025 12:43 AM
My account continues to ask me to reset my password or choose to reactivate my SIM card. But I already have an account and SIM card. What do I need to do to fix this? Thanks!
03-21-2025 04:29 AM
Dial 611 or call 1-855-4PUBLIC on the status of your account.
It is strange that you need to reactivated the SIM card because SIMs are onetime use so you can't reactivate the SIM again.
03-21-2025 12:45 AM
the system cannot find the My Account with your email login, it happens sometimes but PM can help if you submit a ticket. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
