No internet connection on data and can not send it receive pictures or video
JackiemHovan
Hi, I had to reset my phone and like a dummy I forgot to screen shot my settings for data. I only can use the internet on wifi.
I also since resetting my phone I can not send or receive pictures in lest both parties have RCS. Tha is for any help I can get.
9 REPLIES 9
JackiemHovan
Hi I took out the DUN and it worked. Thanks so much. I. Any find where the this worked button is. Thanks again!
JackiemHovan
Hi sorry about that. It is an UMIDIGI_A9 PRO_R_V1.0_20220111
I have had no luck. There is a Telus name in there but I can't make it stay so I was going to copy the information for a new APN
@JackiemHovan what phone brand and model is that?
Make sure the APN is saved and enabled. Some phones has a tough time saving the modified profile
JackiemHovan
No luck , I'll try again.
JackiemHovan
Thanks, I will be back
Dunkman
@JackiemHovan
You will need data/Wifi for RCS to work properly.
Here is link for APN setting for Android phones:
https://www.publicmobile.ca/en/ab/get-help/articles/set-up-data-on-an-android-phone
@JackiemHovan . Create new APN profile following this
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
JackiemHovan
Yes android, ok will do,thanks
hi @JackiemHovan Android? try Reset all networks
