05-09-2023 09:41 AM
I activated nearly 24 hrs and ported my old number from different carrier but still cant receive calls and text. I am expecting a call today. Can anyone have an idea?
05-05-2024 06:57 PM
number sent, please check your community inbox
05-05-2024 06:57 PM
HI @Nayhat34
Sent!!
05-05-2024 06:56 PM
Can you also send me the number for the porting support team. My friend has the exact same problem.
05-09-2023 03:55 PM
did you reboot your phone once ? Reboot once more now and check incoming
I have sent you a porting support team number to your community inbox as well, call them and they will confirm if there was anything missing in the process
05-09-2023 03:51 PM
I did I replied yes! I can call out but not receive any!
05-09-2023 03:48 PM
I’m having the exact same issue. Can you send me the number please
05-09-2023 11:56 AM
@Iceicehey sent.. please check your Community inbox
05-09-2023 11:51 AM
Hi , I have the same issue with porting .Can you please also send me the number please.
05-09-2023 10:17 AM
You are right, i just responded yes..
05-09-2023 10:03 AM
@babybatara wrote:I didnt receive any text for permission to port. Maybe because i took their sim out.. Maybe I should put back incase they text me.
Yes, you should put the old carrier sim card in your phone. I would still call the Telus porting team number to re-initiate the port request. You have a 90 minute window to respond to the port request text.
05-09-2023 09:59 AM
05-09-2023 09:51 AM
Did you respond to your old carrier's port request text? Need to respond yes to the port request, or the port would be declined.
Looks like that your port is stuck. You can contact customer service agent or it would be faster to call the Telus porting team number. This number is used for porting issues only. I will private message you the number. Check your inbox (envelope icon on upper right corner).
