Cannot receive calls or texts
Rwmoose23
Hello it seems like I can only send calls but not receive them. I also cannot send or receive texts...
slusagm
new or existing customer?
did you reboot the phone and Reset network settings?
hi @Rwmoose23
is that a new activation with porting?
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone?  If you cannot the port was not done
It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call
Meow
When did you signed up with PM?
Did you port your number to PM?
