12-11-2023 08:38 AM
12-11-2023 03:46 PM
Try:
Delete the "Proxy" value.
Delete the "Port" value.
Correct the "MMSC" value. (http://aliasredirect.net/proxy/mb/mmsc instead of http://aliasredirect.net/proxy/mmsc)
Double check every other values, including blank ones.
12-11-2023 10:29 AM
It worked briefly on DuckDuckGo but not on anything else, which is why I clicked solved. Now it's back to not working. I can see 4G and the arrows flashing it just refuses to connect.
12-11-2023 10:20 AM
Make sure that you double check what Softtech's post about the APN Setting. Just each individual line and make sure no typos. Save the right settings. It should work then. Maybe reboot phone after saving settings.
12-11-2023 09:46 AM
Now it says I'm connected but the internet still won't work. I miss clicked it being fixed.
12-11-2023 09:36 AM
Everything works except mobile data. The Mobile data does work on my old phone(when IT works) but not on my new phone, I am at a loss as to why, everything should work.
12-11-2023 09:33 AM
your APN was not correct. The line APN was wrong already
should be:
APN: sp.mb.com
Please update and follow exactly what I posted above
12-11-2023 09:26 AM
you said you have an older Blackview and your PM sim works there?
maybe your phone? do you have any friend using Telus or Koodo or PM? test their sim on your phone to make sure it is not a device problem
12-11-2023 09:22 AM
Switching network type didn't work either.
12-11-2023 09:12 AM
@TheMichstache wrote:Ok found these settings and they are all correct. Still no mobile data. Do I have to register the phone or something?
all fields are exactly the same as what I posted?? has to be very careful, a little typo could mess up the data
Also, try changing your network to 3G and test
12-11-2023 09:04 AM
12-11-2023 08:51 AM
How do I see these settings? Reset Network didn't work.
12-11-2023 08:41 AM
@TheMichstache Try resetting network settings
12-11-2023 08:40 AM - edited 12-11-2023 08:41 AM
Your new Blackview BV8800 has all the requied band for PM network and is compatible
Try to click Reset All networks and it should work
If not, it would be an issue with APN settings. Please check and update as below:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
