06-25-2024 09:39 PM - last edited on 06-25-2024 11:12 PM by computergeek541
After when the number was transferred to the public mobile, what's up/ telegram messengers did not show any notification, in case my phone was not disturbed for 15 min. It looks like deep sleep. I have Uninstalled apps and installed them again, deleted the accounts and registered again, checked all settings, and have gave all permission, result is the same. The same history with my wife's number and phone.
06-25-2024 11:17 PM
@will13am wrote:@MaksymG , from what I can tell, telegram only uses the phone number to seed the account. Apart from that, the phone number does not play a role in the functionality of the app and the carrier is not an intermediary. I use my google voice number for telegram and it works fine. There must be something else going on unrelated to your change of carrier brands.
I have used both WhatsApp and Telegram before. The phone number is only used as way for your contacts to easily find you. Both apps confirm that the phone number is yours by sending a text messgae with a confirmation code. However, the actual WhatsApp and Telegram services are using a standard internet connection. Other than providing a possible internet connection, these messenger services and not receivng notfications for messgaes through these service wouldn't be related to Public Mobile.
06-25-2024 10:49 PM
you disable Dave Saver and Power saving mode?
and on Telegram settings, Have your tried the "Reset Notification Settings" button at the bottom of the Notifications & Sounds page
06-25-2024 10:32 PM
Why does it happened after transfering numbers and with 2 different devices (Samsung and Iphone)?
06-25-2024 10:26 PM
Doesn't work. With lucky mobile sim works great, but with public mobile no.
06-25-2024 10:22 PM
06-25-2024 10:03 PM
@MaksymG it has nothing to do with the mobile network, just phone settings
Check if you disable background data for those apps, if you turned on Data Saver. Check global notification settings and notification settings on app level
06-25-2024 09:46 PM - edited 06-25-2024 09:46 PM
Not sure if this will do the trick but you can try toggling airplane mode off and then back on, or better yet power off your phone and turn it back on, always a good thing to do after porting over a number and setting up the new SIM card
