09-22-2023 08:38 PM
Purchased add-on for roaming while in U.S. specifically for navigation and it did NOT provide network service.No network, no maps! And, yes, I had data roaming turned on .Oh, and I've tried submitting a ticket 6 times, clear cache, etc. and error code every time. Very poor customer service
09-22-2023 10:41 PM
maybe you just one step from making it work
Try to manually connect to T-Mobile and AT&T. Try both and see which one works, and make sure network mode is set to 4G/LTE
09-22-2023 09:54 PM - edited 09-22-2023 09:55 PM
@goGogrl_4 wrote:Thanks for your reply.
I restarted my phone numerous times adjusting settings with each .My son now tells me that some areas in the U.S. are no longer supporting 3G. So I probably paid for a service that wasn't going to provide.
The 3G network shutdown primarily affects the calling function. Most phone have had 4G/LTE capability since about 10 years ago, so data should not be affected.
09-22-2023 09:37 PM
Where were you in the US? I’ve never had an issue with US roaming. Did you manually connect to a US provider? Did your phone connect to anything at all? I was there 2 weeks ago and data and texting worked great.
09-22-2023 09:15 PM
09-22-2023 08:46 PM
@goGogrl_4 Here’s a direct link to supooort
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-22-2023 08:45 PM - edited 09-22-2023 08:46 PM
Hi @goGogrl_4
While in the US, sometimes you need to restart your phone while you're there. Plus you sometimes have to go into your network settings and pick Tmobile and restart. That way it's locked on it. Make sense?
If you're back in Canada now you can TRY to reach out to CS for a refund but it's doubtful they will but let us know if they do.
