Esim
11-24-2024
02:35 PM
12-02-2024
07:39 AM
computergeek541
Transfer from Koodo to pm eSIM not activating. I logged in and account say purchase eSIM. I did as first activation was stuck spinning. Purchase complete but no service. Please help needed
Joining Public
12-02-2024 06:46 AM
Hi,
Free eSIM would not activate but of course buying SIM card worked right away.
11-24-2024 02:39 PM
hi @Aj61
did you use the app to activate? did you get to the end of the subscription using the app?
If you did, the app would have installed the esim for you as part of the process. Please go to your phone's Sim Manager screen, check if the Public Mobile esim is there and enabled (or Turn on this line is enabled and set as Primary)
In case you don't see a Publc Mobile esim there, check the Welcome email from PM and there is a QR code to scan and install the esim
If you still need further help, ask PM support,
you can submit ticket by direct message:
