New phone number
03-22-2024
02:21 PM
03-22-2024
10:31 PM
computergeek541
I need a new phone number that has many similar numbers as possible. It will be my new number but I have 2 autistic and 3 blind family members so I need it to be easy for them to dial me
Service
03-22-2024 02:40 PM
You can try to loop available numbers for a few days until you get to the one you like. But it is highly unlikely you will stumble on a number with many similar digits. But it is worth to try, do not give up.
03-22-2024 02:31 PM
In your self service account, you can manually choose your own number. See what is available from Public mobile pools of available new phone numbers. Each mobile company has its owns set of phone numbers to choose from.
https://www.publicmobile.ca/en/ab/get-help/articles/change-phone-number
03-22-2024 02:31 PM
@Clydeiskingcock wrote:I need a new phone number that has many similar numbers as possible. It will be my new number but I have 2 autistic and 3 blind family members so I need it to be easy for them to dial me
Log in to your account / Profile / Current Phone Number...then click on the little pencil beside it...there you can request new numbers. You'll have to cycle through to find number acceptable.
03-22-2024 02:30 PM
Usually you just need to go to Change phone number and keep asking it to give you difference choices and hope to find a good one that you like
but if you have special needs, worth to ask support agent to see if they can help. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
