Never had data for over 2 years?
lorvar1
Hello. I never had the need for data until recently (I drive now) and noticed that my 500mb from my original data plan was never working for 2 years. I upgraded to 3gb a few days ago and my phone still can't connect to 4G for internet outside. It shows the 4G icon. I've updated the APN, but still no change.
13 REPLIES 13
HI @lorvar1   What kind of phone  (make and model ) is that?
You can first start with a Network reset and see if it works.
Darryl69
Did you check if your cellular data is turned on?
dust2dust
And of course you've turned on mobile data. Do any other apps work? Maybe the browser isn't set up to use mobile data.
iliketotalk
lorvar1
Yes, reset networks as instructed, reconfigured APN, etc. I checked numerous browsers and youtube.
lorvar1
First phone was a Huawei P30, which my wife also has. Now I have a Umidigi Bison Pro.
HI @lorvar1  You can update your APN and save without issue?
Make sure your OS is updated to the latest one
And an you send us screenshot of your APN on your device?
lorvar1
I'll have to screenshot later. I tried the same one my wife has on her phone though.
HI @lorvar1   Check space and case of the letter.  Sometimes an extra space at the end or in between could be the reason
