08-13-2023 11:58 AM - last edited on 08-13-2023 12:41 PM by Dunkman
Hi Moderator,
I have point at a Coco bubble tea shop. The way they access the points was by phone number. I recently change my cell phone number. Then when I went to the Coco bubble tea shop they request I show prove of the previous number in order to update the phone number on the Coco account. Please help, I need a confirmation that my previous phone number belongs to me before. Your help is greatly appreciated. Ty
Previous number 905-xxx-xxxx
New number now 705-xxx-xxxx
Edit by Dunkman: removed personal information
08-13-2023 11:37 PM
Greatly appreciate your help. Thank you
08-13-2023 11:36 PM
Thank you, I'm new to here.
08-13-2023 12:30 PM
Somebody should call the old number and advise them they have a ton of points to use at CoCo Bubble Tea Shop using their number. LOL
08-13-2023 12:11 PM
You should probably remove your phone numbers because this is a public forum, and we are all customers like you. If you want direct help from Public Mobile you would need to send a private message to @CS_Agent .
That said, if your number is gone, it's likely gone. Not much you can do. Did you get the number originally from PM, or did you port it in from another carrier. How long have you not had that number for?
08-13-2023 12:05 PM - edited 08-13-2023 12:10 PM
edited...sounds like a Coco problem...not a PM prob. Previous number doesn't belong to you if you changed your number.
