01-04-2024 04:19 PM
My phone number transfer did not go through according to Public Mobile but my previous carrier is no longer working and now I don’t have a cel phone number.
I need someone from public mobile to contact me
01-04-2024 04:57 PM
This might be a porting related issue. I had a similar situation but was able to get it resolved. I suggest contact the number of the porting team. They should be able to help you! 🙂
01-04-2024 04:35 PM
HI @Jordanp1
yes, support agent will contact you via Community inbox,
but please contact them first. please submit a ticket with CS Agent here:
01-04-2024 04:34 PM
@Jordanp1 No one will contact you , you need call the porting team. Number and get the to re trigger the port request for you . Will send it to you private message
01-04-2024 04:21 PM - edited 01-04-2024 04:22 PM
Hi @Jordanp1
I'll send you the porting team number to assist you with the transfer. Check top right corner for number.
You can also reach them via this link.
