09-05-2023 10:43 AM
I am unable to make calls as the calls do not go through. (Failed calls)
I heard a few days ago that bell was having some issues close to my area. Is this still the case?
Marilyn
09-05-2023 11:23 AM
@Marilynhans1 Please use this direct link to support to help
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-05-2023 11:21 AM
Rebooting my phone has not worked. Q. If there is a problem, is Public Mobile aware of it - and how do I know if the problem is being fixed??
09-05-2023 10:53 AM
09-05-2023 10:47 AM
@Marilynhans1 wrote:I have had this account for years and usually have no problems.
Gotcha. I'm gonna guess that the issue is a local network problem, especially if those other guys were experiencing similar problems. Try the cell in a different part of the city, if possible.
09-05-2023 10:47 AM
I am unable to test the Sim card to see if it works. I only have one phone. I will try rebooting the phone as you have suggested.
09-05-2023 10:46 AM
Try rebooting your phone by powering off then power back on but check the Bell outage map:
09-05-2023 10:45 AM
09-05-2023 10:44 AM
@Marilynhans1 Try rebooting the phone or reset network settings se did that helps . Also is it possible for you to try the SIM card in another phone to test
09-05-2023 10:44 AM
is this a new account or has it worked successfully up to this point ?
