02-07-2025 03:26 PM
02-07-2025 04:01 PM
send the message to PM support, thank you for your help
02-07-2025 03:39 PM
hi @SlawekJ
try changing to the different network mode: 3G and 4G (or LTE)
if same, ask PM support to check and refresh the account, you can submit ticket by direct message:
02-07-2025 03:34 PM
no, no voice, no text, my account looks ok, everything paid, rebooted already, opened and closed the sim card, turned airplane mode on, and off after several minuts, nothing helped
02-07-2025 03:30 PM
hi @SlawekJ
voice and text work?
did you login My Account and check if your account is active or suspended?
if it shows suspended, click Pay and Resume Services and make a manual payment
if it shows active, then reboot your phone and try Reset Network Settings. Also, try the sim on another phone.
