02-07-2025 02:08 PM
02-07-2025 03:16 PM
hi @Nito
did you Reset network settings on the phone? and test changing network mode on both 3G and 4G
if you have physical sim , test on another phone
Last, ask PM support to check, you can submit ticket by direct message:
02-07-2025 03:09 PM
My account is active. The msg I get when rebooting the phone is that public mobile network is not available. I checked the SIM card and appears ok
02-07-2025 02:50 PM
hi @Brigit do you meant it does NOT take payment?
PM payment system is glitchy sometimes
if your plan not expired or suspended yet and you still have time, please wait a day or even longer before you try again. When you try, try using both Incognito/private/secret mode on your browser and try with Public Mobile app (with Location Permission enabled)
but if your plan has already expired or you need to pay it very soon, then buy a voucher from Shoppers drug mart or gas stations and then load the voucher using *611 or My Account
02-07-2025 02:39 PM
Same for me, it does take my payment, I reset my credit card number . Still not working
02-07-2025 02:12 PM
hi @Nito
did you login My Account and check if your account is active or suspended?
if it shows suspended, click Pay and Resume Services and make a manual payment
if it shows active, then reboot your phone and try Reset Network Settings. Also, try the sim on another phone.
