05-30-2023 08:47 PM
Pixel 6pro esim. I do not see the phone number in the system information. It is not in sim 2.
Also the mobile network is now running at 14 percent.
How do I check the setup. Can I reinstall the esim. David
05-31-2023 08:48 AM
HI @DavidSchnare I think that is a good question for support, can the same QR code be used on a reeet phone. I think NO. and I don't suggest you to do it. I saw post that people cannot move eSIM to another phone at this stage. So, the eSIM process is fairly new and not everything setup like other provider
But when you call others, do they see you on the caller ID? If they do, why you so worry you don't see your number in the About screen?
05-31-2023 08:44 AM
Can esim be reinstalled if I reset phone?
05-31-2023 08:44 AM
I did the network reset. It did not help.
I did not delete esim. Can esim be reinstalled if I reset phone?
05-30-2023 08:52 PM
@DavidSchnare try reboot the phone and reset all networks.
And does the phone works ? can you make and receive calls?
05-30-2023 08:50 PM - edited 05-30-2023 08:50 PM
@DavidSchnare Can you try resetting netwotk setting and or reboot the phone and see if it helps
