01-15-2022 10:31 PM
I have tried everything to get my iPhone service but it is not working, I talked to apple support and they told me to talk to my carrier
01-15-2022 10:32 PM - edited 01-15-2022 10:32 PM
When did the problem start? Have you tried selecting the network manually?
You may also try switching between 4g/LTE and 3G/WCDMA modes.
01-15-2022 10:33 PM
@alexisevans016 Account is showing Status Active on your My Account?
did you try to put in another SIM in your iphone just to confirm it is not a device issue?
did you try to put your PM SIM in another phone to confirm if it is the SIM or account?
01-15-2022 10:36 PM
I think it is more of an iPhone issue because when I put other SIMs in my phone it still doesn’t work. But apple support useless and I just wanted to make sure that I wasn’t missing anything
01-15-2022 10:38 PM
@alexisevans016 - can you please share the troubleshooting you have already tried, so we do not just repeat something you may have already did.
FYI, we are customers, just like you, here on the forum. And would be happy to try and help. Please provide details, when did you activate, did you have services working previously, are you using a new phone, etc.?
01-15-2022 10:39 PM
@alexisevans016 wrote:I think it is more of an iPhone issue because when I put other SIMs in my phone it still doesn’t work. But apple support useless and I just wanted to make sure that I wasn’t missing anything
@alexisevans016 I would put the PM SIM in another phone to confirm as well.
Also, did you try to plug in your phone to a computer and get all the latest update as well as latest carrier update? that might help
01-15-2022 10:40 PM
Check below:
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
01-15-2022 11:22 PM
And you were using this iPhone previously?
Check if it has been blacklisted here https://www.devicecheck.ca/check-status-device-canada/
When a phone stop to recognize the network all of the sudden, check Telus service outage here https://www.telus.com/en/bc/outages I know you said everyone around you have service but is that Telus network service?
Is there any other change in settings?
and another one... Check your status of account in self serve in case you are near your renewal date.
01-16-2022 02:26 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
APN Settings On An IPhone click Here link,
Ensure you have the correct APN settings by visit Here link,
Select the brand and model of your phone,
and try manually selecting network "3G ONLY"
for iPhone visit Here link
or Here link
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
try to check update your device,
you can try to test your SIM card in another device to you know the issue from SIM card network or your device issue.
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent,
Good Luck..
01-16-2022 02:37 PM
