01-06-2024 07:50 PM
I want to know if I can move my number to Public mobile with esim to esim.
If I download Public mobile esim, can I still get old provider's confirm message for transfer?
01-06-2024 07:56 PM
HI @Eunhee
more inforamtion on the eSIM setup and porting when you have esim on both old carrier and PM
https://www.publicmobile.ca/en/ns/get-help/articles/transfer-your-number
01-06-2024 07:55 PM
@Eunhee No you can have multiple eSIM on a phone
01-06-2024 07:54 PM
so, downloading PM esim doesn't look overwriting old esim ?
01-06-2024 07:53 PM
HI @Eunhee
you will just activate as usual, and and then pick eSIM in the subscription and eSIM is free
make sure you keep the old provider eSIM on for now as you will need it to receive text from old provider to approve the porting. Once aproved, you can disable , but not delete, your old carrier esim and enable your PM esim and make it Primary
01-06-2024 07:51 PM - edited 01-06-2024 07:52 PM
@Eunhee !yes you can transfer number over to PM from another provider using eSIM . You can do this on activation of PM account
