06-14-2022 07:23 PM - last edited on 06-14-2022 07:35 PM by Dunkman
Hi,
May I use TELUS ZTE Cymbal 2 8GB - Black - Prepaid phone?
https://www.bestbuy.ca/en-ca/product/telus-zte-cymbal-2-8gb-black-prepaid/16158346
Thanks.
10-02-2022 07:37 PM
Thank you 🙂
10-02-2022 07:34 PM
Yes it does.
10-02-2022 07:16 PM
Thank you for your comment. I just posted the 4G question for this phone. This question is answered but would you know if it has Bluetooth? Thank you. 🙂
06-14-2022 09:19 PM
Your ZTE Cymbals 2 is compatible with PM on 4G.
06-14-2022 07:59 PM
Are you a pc optimum member? You can purchase a phone outright from The Mobility Shop by redeeming half the cost of the phone in points. The Cymbal ZTE 2 is $74.99. Redeem 40,000 points and pay $35.99+tax for a brand new phone.
06-14-2022 07:36 PM - edited 06-14-2022 07:42 PM
Yes I have one.
Edit:
But I wouldn't necessarily buy it at that price from best buy for an open box phone with a 15 day return/exchange policy. At least public mobiles comes with a 30 day no hassle return, one year warranty and a free sim card and its $15 cheaper. Shop around a little before you buy....I will even keep an eye out for you.
06-14-2022 07:24 PM
HI @umts123 Yes, PM is using Telus network. So, any Telus phone will work here
and yes, this phone will work without problem
