02-11-2024
05:00 PM
03-11-2025
08:59 PM
computergeek541
Like so many others, my MMS just stopped working all of a sudden. Changing the APN settings and contacting CS agents did nothing to fix the issue. I have the OnePlus 7 Pro, and it's a 2019 phone. Dropping support for a 2019 is ridiculous...
03-09-2024 02:59 PM
If it helps anyone else I was able to solve this!
I have had this issue for the last 2 weeks. I have a Oneplus Nord N200, and the steps didn't work on the first few tries. I had to delete/reset the APN 5 times before it randomly worked. On the last delete, it set the APN to "sp.telus.com", i switched it back to "sp.mb.com" & sent my self and MMS and it finally worked:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
APNtype: default,mms
03-06-2024 07:41 AM
Worked with a Poco F5 and Remi note 8 Pro
03-06-2024 07:15 AM - edited 03-06-2024 07:54 AM
did these settings work for you on a oneplus phone? specifically a oneplus 7 pro.
thanks
03-05-2024 03:39 PM
Thank you. This worked for me
03-03-2024 09:08 AM
Very disappointed in Public/Telus. This solution worked for us.
I seem to think this change is all about the APN. Check for these settings in your APN.
Name: whatever you want
APN: sp.mb.com
MMS proxy: mmscproxy.mobility.ca
MMS port: 8799
APN type: default,mms,dun
APN enable/disable: APN enabled - probably on anyway and greyed out
MVNO type: GID
MVNO value: 4D
Save, then select to use, then go in and out of airplane mode
02-14-2024 01:25 PM
HI @CalvinW
we have a suggestion here, try and let us know if it works
02-13-2024 06:20 PM
Legacy mms dates back to 2014 or earlier. That a 2019 phone uses the old technology is a bit surprising but not entirely unexpected. My device is 10 years old. That TELUS no longer supports it on their network in 2024 is unsuprising. Unfortunately, it wil cost me at least $600 to get a new equivalent device that TELUS/Koodo/Public Mobile can support.
02-13-2024 06:17 PM
It is not going to help to switch to TELUS or Koodo. TELUS is the network owner for Public Mobile, Koodo, and Public Mobile. TELUS is the one that has removed legacy MMS server support at the start of February 2024. Their actions have affected Public Mobile and Koodo. Hence why people on all three carriers with older devices can no longer send photos as part of their texts, or participate in group texts with multiple friends, etc. TELUS announced previously that they were doing this. https://www.telus.com/en/support/article/multimedia-messaging-browsing-services-update The workaround here is to get a supported device, or to leave for another carrier on a different network. Chances are quite high though that Bell will also do this if they haven't already done it. Bell and TELUS has the same network technology in many cases. Unfortunately, TELUS doesn't want to support 2014 technology in 2024.
02-13-2024 03:41 PM
It's just a major inconvenience, since my OnePlus 7 Pro is my business phone. I can tell existing customers not to send MMS, but I can't possibly inform new customers that. I don't want to bother explaining to all my customers why Public Mobile has lousy MMS support. Keeping my personal phone with PM is fine but I guess it's time to switch carriers for my work phone. Public Mobile being a lower tier carrier makes sense now, reminds me of Wind Mobile back in the day.
02-13-2024 01:43 PM
sorry @CalvinW
not sure why. But it is not unusual not all brands have the same support. Seem like the new server does not work well with OnePlus. But why change carrier, there are other ways to send pictures.
02-13-2024 01:32 PM
After numerous back and forth between CS Agents and then subsequently forwarded to the technical department, their conclusion is "Network doesn't support your phone, please upgrade your phone". For context, I use a OnePlus 7 Pro, a 2019 phone. If they are dropping support for 5 year old phones, what's the point of upgrading? They will just drop support for my new phone in 5 years. Better to just upgrade my carrier instead...
02-12-2024 01:10 PM
I used this settings and it worked!
APN: sp.mb.com
MMS port: 8799
MCC: 302
MNC: 220
02-12-2024 12:53 PM
Freedom works? Sounds like I may be moving there... Thank you @CalvinW
02-12-2024 12:42 PM
OnePlus 8 Pro too.. that's a year newer.
02-12-2024 12:17 AM
Hi CalvinW,
I have the new OnePlus 12 and have the same issue you have. I have been playing around with the settings and got it to work. I checked with a family member who has the 8T with the same issue and this made it work for them too. I'm not sure what exactly made it work again but here are the steps...
1. In the mobile settings for you SIM slot for PM, just before you go to the APN select, make sure your SIM phone number has a "+" in front of your phone number. Not sure how important this part is, but I'm recreating what I did to make it work.
2. Go into the APN selection screen and it the 3 dots in the top right corner and hit reset access points. Then go into your APN and confirm that the details are correct as stated in PMs updated details.
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-android-phone
3. Reboot or just turn on airplane mode and off again.
Seems to work again for me.
Hope this helps.
02-11-2024 05:37 PM - edited 02-11-2024 08:33 PM
hi @Phil_Adelphus I don't think that MMS compatibility list means anything. MMS is just a basic service that will work ask long as the phone is compatible. Right now the issue is just about older models phone as legacy MMS server retiring. If MMS really only works on phones on that list and no more, I think Telus would loss a quarter of the subscribers. The list is pretty much just a recommendation for bigger brands for easy support
02-11-2024 05:32 PM - edited 02-11-2024 05:33 PM
@CalvinW PM doesn't list any One Plus in their MMS compatible list
https://www.publicmobile.ca/en/on/get-help/articles/picture-messaging-updates
Having said that, there are complaints on other carrier forums about that particular phone not getting MMS including on the OnePlus community. Interestingly one person fixed it by enabling "auto download MMS while roaming". I seem to recall someone else doing that here in the Public Mobile community but I don't remember if it was the exact same problem. Might be worth a try.
02-11-2024 05:24 PM
hi @CalvinW for some reason, OnePlus phone got hit hard with this MMS server issue. If you decide to move carrier, and considering Telus or Koodo, make sure you test a sim from a friend first
02-11-2024 05:23 PM
Admittedly so, @CalvinW , they have an obligation to determine whether it's a device-related issue or a system issue.
I believe it does have to do with their changes.
And if that's the case, and they do not have a workaround for you, I can certainly understand you wanting to jump ship.
02-11-2024 05:20 PM
I saw that announcement. Didn't think it would apply to a 2019 phone. I'm contacting another CS agent right now. If MMS still doesn't work, I'm just gonna switch from this questionable network. Don't want to get a new phone and watch Public drop support again. Going to be a vicious cycle...
02-11-2024 05:16 PM
Read over this announcement - I'm shocked this might be the cause of your issue. Firmly request that the customer support agents find out if it is.
I'd be furious with a 2019 device, if it is.
02-11-2024 05:06 PM
Yeah I tried everything. Unfortunately it refuses to work. I tried my sister's SIM card who's with Freedom Mobile on my phone and MMS works fine. No idea what's going on with Public Mobile...
02-11-2024 05:04 PM - edited 02-11-2024 05:05 PM
That IS ridiculous @CalvinW
Try resetting network connections and removing and reinserting your SIM card to see if that may enable MMS.
Also, I presume your data switch is toggled ON.
Try the SIM card in another device to see if MMS works. Then, try another person's SIM in YOUR device to see if MMS works.
At that point, the customer support agents must remedy this issue for you.
