4 hours ago
I have reached my maximum data limit of 50GB. I should have unlimited data at slower speeds but unfortunately PM has cut off my data altogether.
Please help.
2 hours ago - last edited 2 hours ago
Yes. You did answer your own question. HOWEVER @StuGattz you may wish to change it to the Canadian $34 which is still 50GB but throttled at 512kbps. Honestly, I'm not really sure what 512kbps is like on Public Mobile. You COULD wait till the next few rounds of the $34 Can/US 50GB plan as they may change it back to unlimited. Only time will tell.
EDIT: Did you know for $6 more you get the same plan but 75GB of data? Then $16 more you get 100GB of data?
3 hours ago
@StuGattz wrote:I have reached my maximum data limit of 50GB. I should have unlimited data at slower speeds but unfortunately PM has cut off my data altogether.
Please help.
Look in phone settings to see if there is a max data lmit cutoff set. If that is turned on, data would stop working once the phone's data counter reaches the set limit.
3 hours ago
You can switch plan to $34 50GB Canada only plan, or if you are interested in Canada and US plan, there are $40 75GB and $50 100GB
3 hours ago - last edited 3 hours ago
why new provider, you picked the wrong one yourself
there is a $34 Canada only plan with what you want, unlimited data. Login My Account and xhexj Change Subscription
if not there's since price is same, ask PM and see if they can switch over to thar plan
but to me, I think the Canada US plan worth more with the roaming feature
3 hours ago
I think this answers my question.
Time to find a new service provider.
4 hours ago - last edited 4 hours ago
@StuGattz check to make sure you didn't set a data mimkf on your phone
and check My Account again and confirm what plan you signed up for, I hope not a Canada US plan which does not have unlimited reduced speed data
4 hours ago
Hello @StuGattz
Which plan do you have? And how old is the plan? If you can take a screenshot of the plan, that would help us figure if you actually SHOULD have data or if your data bucket ends at 50GB.
4 hours ago
@StuGattz Which 50GB plan do you have? Both are $34 but one is Canada-US and the other is Canada only. Only the Canada-only plan has unlimited throttled data.
