04-14-2025
09:44 PM
04-14-2025
11:39 PM
computergeek541
Is the data from points good till it’s over or does it expire? Is there any that don’t expire?
What if I buy the add-on data? Does it also expire in a month?
04-14-2025 10:29 PM
04-14-2025 09:55 PM
The data add ons purchased via rewards points expire after 30 days. The same goes with add-on data purchased with cash.
If you need to purchase data add ons frequently, it might be worth upgrading plans.
04-14-2025 09:54 PM
@Taha2 wrote:Is the data from points good till it’s over or does it expire? Is there any that don’t expire?
Both types of data add-ons expire after 30 days.
