Data and texting not working
Mel1na
My daughter just got an eSIM with public mobile and she can make calls but that’s it. No data, no texting and now iMessage is not working either. Incredibly frustrating.
Dayniel
*update:
sent a support ticket last night and they had me shut off the phone for 5 minutes. I did 30 minutes and powered on again. The past few days under iMessage and FaceTime my phone number was “verifying” but finally it completed and I was able to click the number and have a check mark ✅ beside it. Sending and receiving texts works properly again.
Dunkman
@Mel1na @Dayniel
You can also try a network reset of phone (note: this will erase any saved Wifi passwords).
Also, remove any old physical SIM card or deactivate/turn off previous old eSIM.
@Mel1na
Try rebooting her phone by powering off then back on and see if that helps.
If not, it could be a porting issue with eSIM if she ported her old number over from another carrier or picked a new number. She will need the assistance of a CS_Agent to investigate the issue. Click on Chatbot and type in Submit a Ticket or dm them.
Dayniel
Exactly the same situation.
