Loss of MMS for $15 plan customers June 2023
EdN
Friend on the $15 Public Mobile plan received a text from public mobile that as of June 2023 his plan will no longer support MMS has anyone heard of this or know of this? Thank-you
7 REPLIES 7
treefrog
@EdN
Looks like your friend needs to upgrade his phone. Only customers affected by this received a text message of these upcoming changes.
@J_PM
I guess those who are using older models of phone will also be affected by this Telus service update as well:
https://www.telus.com/en/support/article/multimedia-messaging-browsing-services-update
Would be nice if PM can make an official notice on this topic and pin it on the Announcement section
thanks
dabr
@EdN   Yes, it's related to PM/Telus not supporting MMS or group messaging on older phones although internet browsing will not be affected.  Also it won't matter which plan the customer has, so perhaps an upgrade to a newer phone might be needed depending on how important that feature is to your friend.
HI @EdN   it is because of this and his model of phone is on the list:
hairbag1
I have that plan...had it for a coupla years. Haven't heard anything of the sort from PM.
Yummy
So far, no such SMS from PM. Everybody is different and use mobiles differently; I would not care less if they cancel MMS. There are free voip apps to do that and there will be no more confusion 'why MMS did not go through - activate data, etc.'.
will13am
@EdN , I think it has to do with the model of phone being outdated.  What phone is your friend using?
